300 starter relay update
Posted by Zachary Hoyt on September 01, 2012 at 07:35:00 from (184.12.70.98):
I got the new relay yesterday and put it on. Now it starts and the starter stays off except when I push the momentary switch, but when I shut the tractor off the first time it kept running. I found out that there is battery voltage to the I terminal at all times, and I had thought that it was only supposed to have power when the momentary switch was pushed. After I disconnected the wire from the I terminal the tractor engine stopped just fine. Did I get a new relay with a problem or have I misunderstood how it is supposed to work?
Zach
