Super C Governor Problem
Posted by Bud W on January 25, 2013 at 13:26:44 from (70.242.114.188):
I had posted earlier that my throttle would not move the linkage to the carb on my SC. The consensus was that the spring in the Governor was broke. Well I have it all apart and the spring is in good shape. Is it possible that something in the governor is not allowing the throttle linkage to move the carb linkage? Thanks
