Re: Possible voltage problem w/coil w/res + res. wire in harness
Posted by Bob M on May 27, 2001 at 14:17:34 from (66.66.72.246):
In Reply to: Possible voltage problem w/coil w/res + res. wire in harness posted by Gene on May 27, 2001 at 14:12:53:
Gene - I think your right - you need a coil without an internal resistor. The 2 ohm resistance wire in the harness will take care of limiting the primary current. I'd suggest trying a 6 volt coil and see how it works. ...Bob M
Post A Followup
: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
