Farmall Tractors Discussion Board
Re: Re: Re: Re: HELP! Battery running dead...
Posted by Pete in PA on October 13, 1999 at 19:23:31 from (208.157.96.50):
In Reply to: Re: Re: Re: HELP! Battery running dead... posted by ltf in nc on October 12, 1999 at 20:15:34:
ok, the voltage regulator (this is not going to be too helpful a description - it has no identifying markings on it) is a black cube located to the rear of the generator with one wire coming into the front, and three coming out of the back...difficult to trace where the wires lead...
I did switch positive-to-ground, and after recharging (the dead or dying) battery i was able to get the lights to work, and now when I pull the starter ring, the voltmeter needle dips into the negative side....which i assume is good, yes? before when i tried to start it the needle swung about 5 volts into the positive, which now that i think about it makes little sense. Is this about accurate, or am i completely off base?
Also, thanks for the tip re the magneto / distributor...it has a distributor, i just didn't know if IH decided to hide a backup magneto somewhere...
thanks for all your help (and patience...)
Pete in PA
Post a Followup
: Re: Re: Re: Re: Re: HELP! Battery running dead...
