What's your favorite juice for a stuck motor?Kroil,WD40, or.
Posted by DennisT on July 30, 2010 at 14:40:05 from (63.174.56.72):
I have a stuck Farmall A engine. (See, "1st Farmall," post) The shop in town that re-worked the cylinder head for this tractor a while back told me today to go home and put WD-40 in all the cylinders. I see WD-40 as a, "water displacement," fluid but not as a lubricant. Not sure about using that. I'm thinking a mix of diesel and ATF. Kroil would be a good idea if it were not so expensive in the quantities required. (I plan to pull the plugs and put about 6 oil-can squirts of something in each hole)
What's your favorite juice for this purpose?
Dennis
