Re: No start A Farmall
Posted by Gordoro on May 25, 2012 at 02:28:26 from (97.95.47.41):
In Reply to: No start A Farmall posted by Gordoro on May 24, 2012 at 15:37:50:
Sorry about the confusion. It does have a mag. I guess when I see the cap with the plug wires coming out and the mag wire going into it I just think about a distributor. It sure was different just to get to the points. That was the difference. Mag points under a seperate flange with 3 screws holding it on. In a distributor the points would have been in the bottom of the dist. On the mag I took off the cap, that is where I found the coil. Thanks again As you can well see I have never worked on an ignition system like this. But I own the A and it is time to learn. Thanks again Gordoro.
Today's Featured Article - Introduction to the Gibson Model D - by Brandon Burnett. The Gibson Manufacturing Corporation was founded 1946 by Wilber Gibson. The Gibson tractors were made from around 1948 to 1952. The picture shown here is of a 1948 Gibson model D. If you notice, this tractor is driven with a lever. You could get a attachment to convert it to a steering wheel. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
