Re: starter motor will not stop running
Posted by old on August 24, 2014 at 15:09:17 from (209.86.226.34):
In Reply to: Re: starter motor will not stop running posted by homebre973 on August 24, 2014 at 15:02:11:
Trace the path the battery cable goes from the non-ground side and that should lead you to a solenoid. Common for them to stick when they are getting wore out. By the way if it is a key start it has to have a solenoid the ignition switch is not heavy enough to handle as many amps as a starter draws.
