Re: starter motor will not stop running
Posted by homebre973 on August 26, 2014 at 20:18:05 from (209.179.60.56):
In Reply to: starter motor will not stop running posted by old on August 24, 2014 at 15:09:17:
I put the ignition back in and started it. The starter kept running again, so I tapped the solenoid and it shut off. I assume that means it is the solenoid. If I can get the old one off, I assume I can just order a 12 volt solenoid that would fit the IH 340 utility. Thanks.
