Posted by CNKS on December 13, 2008 at 13:47:50 from (216.144.104.128):
This is a problem I have had for a while. Rebuilt engine clutch, TA works, I have not had it apart. Engine flywheel has been resurfaced with the correct step height of 2.188". "Correct" clutch pedal free play is 1 3/8", I have it adjusted to about 2" to keep the clutch fingers from touching the release bearing when the clutch is engaged---I suppose this could mean that the flywheel has been ground too many times, but the clutch DOES disengage. Gears will shift without clashing (provided I let the gears stop turning after pushing in clutch) with the connecting rod between the clutch and TA levers disconnected. With that rod connected there is excessive gear clash. Gears will shift but always with some clash. TA is adjusted to spec, along with various "out of spec" adjustments to try to quiet the gears. I had the main clutch fork brazed, and bushings put in the attaching holes in the clutch rod to remove slop in the linkage. There is still about 1/2" movement in the linkage before the fingers move to disengage the clutch, there was about an inch before repairs. Clutch sleeve and release and pilot bearings are new, the old sleeve was badly worn. With the TA inspection cover removed the TA clutch disengages with the lever pulled back or the engine clutch disengaged. The transmission stops turning when the engine clutch is disengaged, and connecting lever disconnected. When connected, gears clash with the TA lever forward or back. Why do the gears turn with the TA connected and the engine and TA clutches disengaged?
This post was edited by CNKS at 13:49:45 12/13/08.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
