starter motor will not stop running
Posted by homebre973 on August 24, 2014 at 11:45:58 from (209.179.19.61):
I put a new ignition switch into my IH 340 tractor in the Spring, and it worked find. Now 3 months later, when I went to start the tractor by reattaching the battery, the starter motor keeps running and will not shut off unless I disconnect the battery. I can turn the key in any position and nothing happens to stop the starter motor. When I disconnect the battery,then everything stops (generator is shot). Any suggestions what is going on? Thanks
