Farmall Tractors Discussion Board
Re: HELP! Battery running dead...
Posted by Ludwig on October 12, 1999 at 14:10:11 from (208.201.105.253):
In Reply to: HELP! Battery running dead... posted by Pete in PA on October 12, 1999 at 11:46:42:
Hmm, used to charge but now it don't?
Try this, when it's running CAREFULLY remove the ground cable from the battery. If it quits suspect regulator/generator.
Is this a 12 volt system or 6? If its 6 you need positive ground. I'm betting you've got a 12, but I'm unsure why things wouldn't work hooked up to positive ground.
I used a Super M for many hours with the battery hooked up backwards. We used to boost it off the pickup and it would run a good ten or fifteen hours like that. It would even start six or seven times, no problem.
Of course it ate batteries, but what do you want?
Post a Followup
: Re: Re: HELP! Battery running dead...
