Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
Posted by Bob M on November 24, 2000 at 17:55:09 from (172.139.14.95):
In Reply to: FARMALL 130 12 VOLT CONVERSION COMPLETE posted by Jeremy on November 24, 2000 at 17:44:20:
Jeremy - Sounds like you have 2 things going on: 1 - The ammeter is wired backward (should show a couple amps discharge when you first pull out the ign switch and before you start the engine). Solution is to simply swap all wiring connections at the two ammeter posts. 2 - The indicator light staying lit while running says the alternator's not charging. The light should go out, and the ammeter should show a sudden 20 to 30 amp charge as engine RPMs run up after starting. Some possible causes: Wiring is not right, the current rating on the warning lamp is too small (needs to be 200 milliamps or so - like a #194 auto instrument panel/side marker lamp or similar), or the alternator itself is bad. Note - You are fine with no ballast resistor and a 12 volt coil. Good luck, and post back your findings.... Bob M
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
